replacing a 727 trann - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2013, 03:20 PM
QuesoBlanco's Avatar
Hello,
Am i able to install a 700r4 behind a 408 stroker motor? They seem to be a lot easier to find than a a518. Do I just need an adapter or is it a lot of modding?
TY.
Old 09-17-2013, 04:09 PM
RWENUTS's Avatar
You could swap but why replace a bulletproof 727 with a grenade like a 700R4.
Old 09-17-2013, 04:40 PM
Hahahaha. I was just asking if it's possible. I am looking for a A518 but they are rare down here in SoCal.
I really want the overdrive.
Old 09-17-2013, 05:26 PM
johnnyg's Avatar
hold my beer and watch this!
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
Old 09-17-2013, 05:32 PM
RWENUTS's Avatar
What!!
You got a street car. At least that's what you said in the other thread.
Don't need no stinkin' overdrive!!
Old 09-18-2013, 07:30 AM
33Willys77's Avatar
I have a gear vendors on my 727 and love it. A little pricey, but it is strong and works great.
Old 09-18-2013, 09:39 AM
Lol I still drive the freeway. Dang those gear vendor prices :O. Expensive!
Old 09-22-2013, 09:10 PM
pricesgarages's Avatar
id go with the 518 it is the cheapest and easiest swap if built right youll will not have any problems
Old 09-23-2013, 06:54 PM
Last wiki edit: How to make a custom dashboard
Last journal entry: Been a long time
Wiki Edits: 4
If the A518 is hard to find, the 46RE should be more plentiful, and can be converted to non-computer controlled (46RH) with a valve body swap and governor install. I did it a few years back with parts from SMR transmissions in Canada. I have seen a few posts where people have used pressure valves to control the lock up and OD application - I turn the OD on with a switch on the shifter.
727 or 904 martincousino Transmission - Rearend 11 11-22-2011 09:30 PM
another 700r4 and 4l60e trann ? backardracer Transmission - Rearend 6 06-28-2010 08:52 PM
727 needs help! PropanePower Transmission - Rearend 4 05-03-2004 05:36 PM
727 help please nettio Transmission - Rearend 5 02-09-2004 09:57 AM
727 problem - PLEASE help newchevyman Transmission - Rearend 5 10-15-2003 07:24 PM
