Replacing Alternator w/internal voltage regulator type - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2011, 09:28 PM
I am currently using the old voltage regulator system on my 68 Vette with the original type alternator. A friend gave me a chrome plated alternator that has the regulator inside of it. I want to use it. As far as wiring it up do I just need to come off the battery side of that new alternator and go to the battery + side... any other wires do I need to hook up coming to or from the new alternator? The voltage gauage (or lets say amp gauage) is not in use. I have digital gauges (led), and I have the volt gauge hooked directly to the + on the battery. I just don't trust those old type gauges. Any suggestions will help. The new alternator I'm installing will bolt up just perfect with exception I have to use a slightly smaller belt (length).
Thnaks,
Ron - Maryland
Old 04-08-2011, 12:18 AM
Is it a 1 wire or a 3 wire alternator? If it's a 1 wire you'd wire it directly to the battery or the hot wire on the starter.
Old 04-08-2011, 04:54 AM
EOD Guy's Avatar
This is how I did it, the dashed lines are jumper wires and the old reg is removed.
Old 04-08-2011, 08:19 AM
Wires
The alternator I'm I want to use that has an internal voltage regulator has the BAT stud on the back and at the top it has two prongs where a plug plugs in... the plug though only has one wire coming out of it on the side marked 'R', this wire is WHITE in color. The other side of the same plug where there's no wire coming out of the plug is marked 'F' on the alternator which I assume means FIELD. You mentioned wire it directly to the starter, can't I just pick up the same wire off the old alternator that was connected to the BAT terminal of the alternator stud? It will end up going to the battery anyway, I would think. Ok, what do I do with that white wire off the top of the alternator (plug)?
Thanks,
Ron
Old 04-08-2011, 08:27 AM
Repalcement Alternator
Nice diagram!!! One issue though as far as my alternator...... Where there's two prongs where a plug connects, there's only one wire on the plug being used (of course the plug un-plugs). A white wire comes out of the plug and it actually connects where it is marked 'R' on the alternator. The other part of the plug has NO wire, and that is marked 'F' on the alternator which I assume means FIELD. I assume somewhere in the wiring you show one of those wires has to go to the amp/volt gauage in the dash of the car, I may be wrong I'll have to look at my schematics of that car and trace the wire out. I am NOT using the in dash gauge, I have an external led gauge which I just have coming directly off a battery wire. What actually does the terminals atop the alternator used for in that apllication?
Thanks,
Ron - Maryland
Old 04-08-2011, 08:36 AM
So go to your local NAPA or other auto parts store and get a pigtail with both wires. The No. 2 terminal should be connected to the junction block, though it will work if you just route that wire to the BATT stud on the alternator. The No. 1 terminal should be connected to the GEN light on the dash. This is necessary for the alternator to turn on and charge properly. If you don't have or don't want to use the GEN light, you can instead solder a 35 ohm resistor in this wire and connect it to a switched +12V source.
Old 04-08-2011, 08:52 AM
Alternator
Thanks for the reponse.... looking at the alternator I do see a #1 and under that is a letter 'R'. This is the one where the only wire is used but I'll grab another plug with two wires. The car I'm using this on is a 1968 Vette (427 ci). Maybe at one time sit had a light for the dash (gen lite) but I have never noticed one. I am the third owner of this car and when I got it I had all kinds of electrical issues with it. When I turn the key to the on position, I just hear the buzzer sound. On the # 2 stud of the alternator it is marked also 'F' which I assume means FIELD. So, I can go right to the BAT terminal on the back of the alternator like you said, I'd rather do that or maybe just use the red 10 gauge wire that is currently going to the exisitng alternator. I like the resistor idea though, I'll go with that.
Thanks,
Ron - Maryland
New Alternator & Voltage Regulator..but still no charge? wickster Electrical 12 08-04-2011 05:14 PM
Convert External Regulator To Internal Regulator 83F150 Electrical 1 05-18-2008 09:10 AM
59 ford fairlane 500 voltage regulator/alternator platinummobile Electrical 21 01-10-2008 06:39 PM
Alternator/voltage Regulator Question leejoy Electrical 5 03-13-2006 01:32 PM
external to internal voltage regulator TASHAN Electrical 2 09-04-2005 11:13 PM
