replacing aod in 86 stang - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2002, 03:41 PM
Post replacing aod in 86 stang
i bought an 86' gt stang with an aod in may. i blew the trans and replaced it with one i got at junkyard for 300 in mid-june. my throttle valve lever is perminately stuck open amd it never goes into 4th gear. 1-2 and 2-3 changes happen at around 2800 rpm. i believe that this isn't good and my trans is slowly but surely dying. is it possible to replace it with a 3-speed automatic like a c-3 or c-4 with out too much trouble?? what would you reccomend i do???
Old 09-11-2002, 05:24 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I would check out your linkage/cable to your tranny and if it checks out ok, I would drop your pan and see what gives. It shouldn't be all that hard to find the problem because it sounds mechanical not hydraulic. Your tranny will not shift to fourth gear if the throttle valve is sensing more than half throttle regardless of vacuum.
Old 09-12-2002, 05:30 PM
Post
thanks man, i just turned 17 in august, i am kinda good at working on cars from school and experience, but i dont know everything, i changed my tranny w/ 2 ramps for my front wheels and 2 jack stands holding up my rear end. this is all in my garagei might add. i'll try it this weekend and see how things end up. i'll post another soon, thanks again
Old 09-12-2002, 11:15 PM
4 Jaw Chuck's Avatar
Post
A combination of ramps and jackstands are a dangerous combination...if nothing else is available a log or built up 2X4 block is safer. The danger is when you jack the rear axle the fronts can roll off the ramp and onto you, make sure you at least use the ramps on the rear axle and use your parking brake to prevent it rolling when you jack the front end. Remember "ramps out back, parking brake racked".
Don't ask me how I learned this.
— Han Solo
Old 09-13-2002, 01:47 AM
aka Duke of URL
Talking
[ September 15, 2002: Message edited by: KULTULZ ]</p>
Old 09-14-2002, 08:56 PM
Post
[ September 15, 2002: Message edited by: jizawiz ]</p>
Old 09-14-2002, 10:01 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
[ September 15, 2002: Message edited by: BstMech ]</p>
Old 09-15-2002, 01:59 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Exclamation
Not exactly sure what sparked the ill will here guys. If it was KULTULZ's post, I'm certain it was taken the wrong way. Sometimes it's difficult to see exactly what someone's trying to say when all you have is words on a screen.
[quote]Some of the dumb things I have done over the years would fill a book...<hr></blockquote>
This is a good opportunity to make use of the "Edit Post" button .
Old 09-15-2002, 03:09 AM
aka Duke of URL
Thumbs up
OK...I removed the post. Sorry if I upset anyone.
Now, do you allow profanity to remain posted? I thought this was a friendly site, but I was mistaken.
Old 09-15-2002, 07:45 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Sorry, I guessed I got suckered Into that one. I will no longer dignify any posts like that with a reply. Again I Apologize.
Old 09-15-2002, 11:38 AM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
Post
KULTULZ -- my apologies, that comment was not directed at you. I should have been more clear.
I thought your post was right on track, as usual . From where I was standing, it appeared that jizawiz just misinterpreted it, and replied with some inappropriate language.
If it comes down to it, I'll edit jizawiz's post, but I'd prefer it if he did it himself.
Old 09-15-2002, 07:42 PM
Post
sorry peeps
Old 09-15-2002, 11:26 PM
aka Duke of URL
Cool
[quote]Originally posted by Jon:
KULTULZ -- my apologies, that comment was not directed at you. I should have been more clear.<hr></blockquote>
That's OK Jon...My reading comprehension skills seems to be lacking also...
hUkt oN FoNIX - wURx 4 mEE!
Guess you have to allow for it. Nice site...hate to see it degenerate.
