replacing body mounting pads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 08:30 AM
I ahve purchased a body mounting pad and bolt kit from Carpenter reproductions for my 57 ford, before I torque the bolts down in the proper sequence, should I mount the from sheetmetal too to get everything aligned??
Old 01-29-2009, 02:55 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
You get a varied array of answers on this, but I would want everything set before final torque. A front end can be shifted over to align with the rest of the body and no one would be the wiser looking at it, but driving down the road could make it look like it is "dog walking". The more panels you have on gives you more points to measure from to get proper alignment.
Old 02-01-2009, 02:30 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Keep in mind it has a full frame, more than shifting or pointing a front clip left or right, it would be more angling the body along on the length of the frame, obliquely.
Semper Fi
HELP cracks on fiberglass body! Adamrmr Body - Exterior 22 04-23-2008 10:35 AM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 06:57 AM
Measurements before replacing panels robs ss Body - Exterior 2 10-12-2006 01:08 PM
replacing throttle body w/carb. 2.5 chev/pont bullheimer Engine 3 08-13-2005 05:04 PM
body mounting unit97 Body - Exterior 5 09-02-2002 09:51 AM
