i do them with the weldder myself everything is about the same but where you are going to over lap you use a flange too (something like this
https://www.autobodytoolmart.com/p-11628-14330.aspx they have hand ones too) this will make where you overlap level. weld around (skip around so there isnt to much heat) grind welds, ext. good luck
