Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Replacing cab corners
Old 12-08-2008, 12:43 PM
MrPhotographer06's Avatar
MrPhotographer06 MrPhotographer06 is offline
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
ah.. well i wasnt sure if it could be done.. cut to exact fit.. or a little more 1/2"... i wasnt planning on removing the bed since its a a stepside...
i've gotta do a lower inner door part,lower door skin and rocker on the drivers.. then lower inner door on pass,cab corner.. patching on drivers fender and a little bit of welding where the cab goes up at an angle for the support...
[see here ]
