hey brian here a site that show and explains what to do
http://www.repairnation.com/.../cab_...corner_pg1.htm a word of advice stay away from the glue idea welding is always better. i'm building a 91 chev ext cab and a buddy of mine says only glue it if your not planing to keep it. cut out your cab corner about an inch down from where the truck has that body line. cut the replacement so it over laps the cab corner you cut by a quarter inch clamp it in where you like it and put small tacks to hold it in place. when you weld it star by the door and weld toward the box remember to do very small weld and then let it cool then repeat. do not stagger your welds if you go from the door back you will naturaly work out any warping. good luck bud
