Replacing Cab corners and rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2005, 08:05 PM
Hello everyone. This is my first post. I just found out about hotrodders a few days ago when I was doing some research for my most current project. Great Site! I am going to be replacing the cab corne and rocker panels on my 1991 pickup. This is going to be my first attempt at body work, painting, etc. I have read a ton of very informative threads on here over the last couple of days and have learned a lot. I recently purchased a small mig welding machine and I am in the process of purchasing a HVLP spray gun for this project. After reading many posts I am still a little uncertain about the best way to go about coating or priming the inner rocker panels and the underside of the outer rockers. The replacement panels came from the factory with a black primer coating (I believe this is called e-coating ????). Although I have cut most of the rusted areas out, there is still a some pitted rust spots. My main concern is how to properly prep these rusty surfaces or remove the rust. I would like to shoot the areas that I am going to be covering up with an epoxy primer to protect them from moisture, etc…I have attached some pictures of the rusted areas and I was hoping for suggestions on the best way deal with this situation. I realize the heavy rust will have to be grinded or sanded off, but I am more concerned with the pitting that will be left after the heavy stuff is removed (mostly along the bottom edge). I would coat the entire bottom of the panel with por 15 or something similar, but the new rockers will need to be spot welded and I will need bare metal to weld to.
New Rockers
Old 12-06-2005, 11:00 PM
spot blast the rusty areas to remove the corrosion then prime with two-three coats of epoxy primer. Remove any paint and primer from your weld areas and coat them with weld through primer, 3M has about the best weld through coating IMO. Let the weld through coating dry then install your panels and weld them up. When all the work is done and painted spray the inside of the panel with a rust preventative like 3M's rustfighter or Transtar amber coating, these are a cavity wax type spray that coats the inside of your panels to keep them from rusting on the inside.
Another option is to install these parts with panel adhesive which works great for these kind of repairs. With panel adhesive you can actually undercoat the complete interior of the panels except where the adhesive goes then install them, no weld, no burn on the backside. The trick with the adhesive is to fit the parts really well and use backing strips at your cut lines to join the two pieces. I've glued many cab corners and rockers on without ever any problems and they outlast the factory job big time. Fit the parts well because there's no moving them around after the adhesive cures, it's a one shot deal. Bob Sectioning Joints with a backing strip Fusor
Old 12-07-2005, 11:05 AM
Thanks for your reply Bob. My tool arsenal does not currently contain any spot blasting equipment, but maybe I will make a purchase for this project. Would the Speedblaster or Hot Spot from Unitec Manufacturing Corp. be suitable in this situation? It seems to be reasonably priced. Has anyone used this blaster before?
Old 12-07-2005, 01:41 PM
weld thru primer is a heat (welder) activated galvanizing primer, best used on the inside surfaces of overlapped panels that you can't epoxy after welding
doesn't stick well with no heat, use "brush on" just on the welds area for the weld voids
Cab panel replacement help 1969chevyguy Body - Exterior 0 02-29-2004 02:28 PM
aligning rockers and cab corners? Gearhead forever Body - Exterior 5 02-01-2003 04:27 PM
