Replacing camshaft bearings while engine installed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 06:23 PM
I have a 1987 boat with twin crusader (chevy) small blocks. My oil pressure on one engine dropped from 25-35 psi @ 2500+ RPM to less than 10 psi. I also have a metal to metal bearing noise in the top front of my engine. I assume I lost the front cam bearing. If I pull the cam and I have a bad cam bearing, can I replace it without removing the engine?
I have installed cam bearings in a bare block before, but have never removed them. I guess I'll have to remove the oil pan to get the bearings out once I drive them out of the journals?
Can I just knock the old bearings out and drive new ones in?
I know I'll be replacing the cam and lifters along with the bearings.
This is in a 34' boat and for me to pull the engine I will have to get it out of the water and blocked. It will cost over 500.00 just to do that plus storage by the day. I am hoping I can do this in the boat while tied up in my slip.
Old 06-22-2008, 06:43 PM
DoubleVision's Avatar
I wish doing a simple fix as you would like to hear was doable. But, you will have to remove the engine and build it. The metal contaiminates are all over the engine now, and more than likely played havoc on the rest of the bearing clearences. I had this happen to me with a fresh built engine, and it didn`t take any time at all and the engine was shot, low oil pressure, low compression and piston slap so loud it sounded like a diesel. pull it out and build it before it self destructs.
Old 06-22-2008, 07:19 PM
King of my Man-cave.
Originally Posted by xcavater
I have a 1987 boat with twin crusader (chevy) small blocks. My oil pressure on one engine dropped from 25-35 psi @ 2500+ RPM to less than 10 psi. I also have a metal to metal bearing noise in the top front of my engine. I assume I lost the front cam bearing................
There is no reason to assume that you lost the front cam bearing and every reason to believe that you spun some rod and/or main bearings. You'll be farther ahead to pull both engines and go through both of them, I'll bet the other one is not far behind in damage.
There's no fixing this problem in the slip........
tom
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
Coated Engine Bearings Opinion? jleeheat Engine 2 05-20-2008 10:41 AM
destroyed con rod bearings - pics and description - what happened ? lowROLLERchevy Engine 36 12-06-2006 09:10 AM
need help with new engine i installed jlraiders04 Engine 4 06-13-2004 11:50 PM
