Replacing Cooling Fan Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2006, 08:47 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
What clutch unit would you recommend for a 400 hp 400sb? The Non-Thermal clutch or the thermal??? I mostly cruise it in town with an ocasinal spin on the local expressway. Stall is around 2200rpm and on an average day of 80* , the temp chills around 185-190 with a 180 t-stat.I am looking to rid of the P.O.S. flex fan. THX---
p.s. Happy "late" New Year All
p.p.s. I have an 84 cutlass and just installed SS pulleys on it. I was wondering --Do I just get a standard fan or does it have to be reverse rotation???? That always messes with my head Sounds stupid when I re-read it. LOL
Old 01-04-2006, 10:31 PM
Jmark's Avatar
Non-thermal clutches are, in my opinion, not worth the wasted money. They usually spin up way too much and stay spinning all the time. Spend some money and buy a brand name thermal clutch. Use the stock GM fan that goes with it too, can't beat em.
Mark
Old 01-04-2006, 10:56 PM
Slant3's Avatar
84 Mutt
Thank You Jmark. Now I gotta find that old fan in the shed.
Old 01-05-2006, 03:23 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I completely agree. I would also avoid the "heavy duty" thermal clutches. They are so viscous that they drag almost all the time. They are basically TOO viscous in an attempt to overcool an engine in a heavy duty application. I have one on my 454 and its a pain. There is almost never a time when its NOT locked up.
A good GM thermal clutch is your best bet. Period.
Old 01-05-2006, 07:38 AM
tornado-tech's Avatar
I would go with a thermal clutch if you really want a clutch fan but a word of advise. Be careful if you have to space the fan out to get it closer to your radiator and in the fan shroud. I had mine spaced out 2 inches and the bearing in the water pump let go completely taking out my radiator. I found out from other people that the extra weight of the clutch fan especially being spaced out causes much more stress on the bearing due to a leverage factor. I eliminated mine and went with a dual electric fan set-up. It heats up quicker now and stays just as cool as with the clutch.
Old 01-08-2006, 03:59 PM
Slant3's Avatar
84 Mutt
Thats my case. I have to space it at least 2 inches. That is how the flex is on there now. Can I still use my aluminum spacer that I am using for the flex?
I don't like the fact that your bearing failed due to leverage factor.My pump is about 5 years old. Thats something that'll be burned in the back of my head. Waiting for it to let loose.
Fan Clutch Bad After 400 miles? Ghetto Jet Engine 10 04-02-2005 10:21 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 11:09 AM
New fan clutch bad? DoubleVision Engine 7 08-23-2004 07:04 AM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 03:49 PM
Using a spacer with a fan clutch sixty5 Engine 5 07-31-2003 12:00 AM
