Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - replacing damaged rocker 85 Iroc (unibody)
  #21 (permalink)
Old 04-04-2013, 01:33 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
That wasnt a bad fit,
The pillar still has to go forward a bit but I still have a LOT more cutting to do....I'll take out the inner rocker and since the floor has an upward hump in it I believe when I push the floor down straight most of the pillar will go forward...Then i'll cut out the pillar and replace that...
.Here all the inner structure is test fitted,making sure all my holes from cutting the welds are lining up,they HAVE to line up or something isnt right,remember the donor was straight so when it all goes back together if the holes line up everything is straight..if they dont something is wrong somewhere..
ID:	72912   Click image for larger version
ID:	72913   Click image for larger version
ID:	72914   Click image for larger version
ID:	72915   Click image for larger version
The Following User Says Thank You to deadbodyman For This Useful Post:
OldF250XLT (05-28-2014)
