Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - replacing damaged rocker 85 Iroc (unibody)
  #22 (permalink)
Old 04-04-2013, 01:51 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Using drill screws I put the whole assembly together,beat on it some more with BIG hammers untill all my weld holes line up perfectly then it comes back apart and I start welding the inner pillar together (I spliced it ,btw, I also spliced the inner rocker back as far as I could go without getting into all the reinforcement braces ,that would be a night mare and I'm sure its in good shape right there because I laid the new piece over it to be sure...
ID:	72917   Click image for larger version
ID:	72918   Click image for larger version
ID:	72919   Click image for larger version
ID:	72920   Click image for larger version
The Following User Says Thank You to deadbodyman For This Useful Post:
OldF250XLT (05-28-2014)
