Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - replacing damaged rocker 85 Iroc (unibody)
  #26 (permalink)
Old 04-04-2013, 10:56 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by deadbodyman View Post
At the begining of the thread I explained that I didnt want holes in the outer rocker from from drilling out the welds because I wanted to weld them on from the backside heres why...just a slight burn spot that needs very little prep and NO grinding which saves a ton of time plus its not only faster it looks better,in my opinion....
Tomorrow I hang the door....If it fits
yep. Did the same on the last rocker I did, which was a nomad. Was worried on that one cause no support to mock up fenders. nothing a little slice in the rockers can't handle. Great work!
I know that feeling. The same feeling I got when I welded in a hinge pocket on a chevy truck. Someone on line told me it was fine to do with no bracing and like a dummy I listened. Soon as I cut that thing out it was like the titanic. I had to measure the other side on top of all my bolt hole measurements and STILL was worrying at home before the weld in.
