Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - replacing damaged rocker 85 Iroc (unibody)
  #28 (permalink)
Old 04-06-2013, 09:12 AM
tech69 tech69 is offline
put up or shut up
that door looks pretty hammered as if the body line is pushed in? That would be the final straw for me on that door if so. If the new one lines up the same why not give the door a little lift w/ a jack in the back when no one's looking to raise the body line? With the welded in hinges you probably don't have much choice. Great job btw. Never had to weld in a pillar holding in a welded on hinge but I can see the importance of it having to be perfectly placed. Great work, as always.
