Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - replacing damaged rocker 85 Iroc (unibody)
  #46 (permalink)
Old 04-08-2013, 06:16 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Yup,I got a big surprize today ,I found out what SPI red looks like.but I dont want to get into that right now...I'm totally sick about it...
Before I get into that My day started out great I seam sealed the pillar I epoxied yesterday,then hung the door again...I want the door on so I can check the gaps as I'm replacing the 1/4 ...Then I cut out the field of the 1/4...and ran smack into a perfect example of why I leave those plug welds a little proud so they can be seen if they ever have to be removed again ....You just never know when one of your repairs will come back for new repairs and you run into your own work...well since I'm replacing the 1/4 I had to remove a few of my own welds it was easy all I had to do was drill my 1/8" hole in the center then drill that out with the bigger bit.it poped right off..then I reinstalled the striker support so I could close the door and put it outside for a while.
ID:	72987   Click image for larger version
ID:	72988   Click image for larger version
ID:	72989   Click image for larger version
ID:	72990   Click image for larger version
