replacing damaged rocker 85 Iroc (unibody) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-01-2013, 07:05 AM
deadbodyman's Avatar
Wiki Edits: 11
LOL,funny you mention that...Yesterday I started taking apart the damaged rocker with a sawzall and made a vid it only took a couple min to cut out everything and it took the rest of the day to drill out all the welds. The sawzall is a "must have " tool ...The plasma cutter ,not so much,in fact using a plasma can really screw you up if you cut through something you'll need ,whats nice about a sawzall is you can feel what you are cutting and as soon as you hit something hidden you can feel the difference and stop to check out what it is before its to late...Plasma cutters have their uses but be smart where you use them ,floors have braces ,rockers have inner structures that are hidden until you peel back a layer,I prefer the sawzall....and VERY SHARP drill bits....
Yesterday I got most of the damaged rocker off...I found a lot of extra damage and I'll have to dig deeper than I thought good thing I took the donor chunk apart like I did I'll be needing most of the parts ,maybe all of them...
I took many pics and a few vids but my USB is full so I need another one to down load my camers into ,then I have to figure out how to get the vids downloaded from that to here...
The Following User Says Thank You to deadbodyman For This Useful Post:
OldF250XLT (05-28-2014)
  #17 (permalink)
Old 04-04-2013, 06:24 AM
Wiki Edits: 11
still having trouble with the vids so pics will have to do for now....
so I have all the pieces seperated from the donor and I'm ready to cut the damaged rocker out ...with my sawzall I cut the perimeter of the rocker leaving all the welds in tact ,I'll drill and seperate them next as strips more easily handled and easier to get at.Theres a few that are hidin and cant be reached with the rocker in the way.it takes about 5 min to remove the rocker skin...
ID:	72878   Click image for larger version
ID:	72879   Click image for larger version
ID:	72880   Click image for larger version
  #18 (permalink)
Old 04-04-2013, 12:41 PM
Wiki Edits: 11
Opps,
Before anything got cut on the car I had to adjust the door gaps the best I could and get a better idea whats going on these hinges are welded on so theres very little adjustment.
from every thing I'm seein it looks like the bottom of the hinge pillar is pushed back a little...Why ? because the bottom of the door is tight and the top is wide but adjusted to ok,plus from the damage I can tell the old door really got shoved into the 1/4 especially at the bottom where the 1/4 was all bent in about a 1/4" so they changed the door, I checked its a different color...And the rocker has a an upward bow so I'm sure the pillar needs to go forward a little.....
Now that I know where all the damage is and what I'm replacing I'll jack up the car to a workable hight...the jack stands HAVE to be under the suspension so its just like it was sitting on the wheels....
ID:	72897   Click image for larger version
ID:	72898   Click image for larger version
ID:	72899   Click image for larger version
ID:	72900   Click image for larger version
  #19 (permalink)
Old 04-04-2013, 12:48 PM
Wiki Edits: 11
The jack stands in place ,wheels off and remove the door....start cutting...
ID:	72902   Click image for larger version
ID:	72903   Click image for larger version
ID:	72904   Click image for larger version
ID:	72905   Click image for larger version
  #20 (permalink)
Old 04-04-2013, 01:07 PM
Wiki Edits: 11
HEY, he didnt put any bracing in the door jamb....LOL
Before you guys have a heart attack....Heres why....
Any bracing will keep it from moving.....I want it to move as I cut out more and more...The hinge pillar has to go forward and I suspect as I cut out more and more it'll relax the metal and spring back and all my new stuff will fit just right...I'll be using just about all of my donor parts...including the inner pillar ,hinge reinforcement and the outer pillar.. Theres actually a lot of damage still here If I had spotted all this damage I would have used this car for all its parts for my 54 P/U which was my original intent...
I cut out everything and beat a few things back in place then test fit the new rocker (I found a red one)...
ID:	72907   Click image for larger version
ID:	72908   Click image for larger version
ID:	72909   Click image for larger version
ID:	72910   Click image for larger version
  #21 (permalink)
Old 04-04-2013, 01:33 PM
Wiki Edits: 11
That wasnt a bad fit,
The pillar still has to go forward a bit but I still have a LOT more cutting to do....I'll take out the inner rocker and since the floor has an upward hump in it I believe when I push the floor down straight most of the pillar will go forward...Then i'll cut out the pillar and replace that...
.Here all the inner structure is test fitted,making sure all my holes from cutting the welds are lining up,they HAVE to line up or something isnt right,remember the donor was straight so when it all goes back together if the holes line up everything is straight..if they dont something is wrong somewhere..
ID:	72912   Click image for larger version
ID:	72913   Click image for larger version
ID:	72914   Click image for larger version
ID:	72915   Click image for larger version
  #22 (permalink)
Old 04-04-2013, 01:51 PM
Wiki Edits: 11
Using drill screws I put the whole assembly together,beat on it some more with BIG hammers untill all my weld holes line up perfectly then it comes back apart and I start welding the inner pillar together (I spliced it ,btw, I also spliced the inner rocker back as far as I could go without getting into all the reinforcement braces ,that would be a night mare and I'm sure its in good shape right there because I laid the new piece over it to be sure...
ID:	72917   Click image for larger version
ID:	72918   Click image for larger version
ID:	72919   Click image for larger version
ID:	72920   Click image for larger version
  #23 (permalink)
Old 04-04-2013, 05:33 PM
Wiki Edits: 11
Well it looks like everything relaxed as I thought it might everything seams to be going together nicely BUTactually putting the door on will tell fer sure,with these welded hinges and no adjustment everything has to be "Dead On" I'll be sweating hanging the door tomorrow....I cant see having any trouble at all but I always worry to tell the truth...
What do Y'all think??? Will it fit? LOL...How bout this ,if it dont I'll bet I can MAKE it fit
  #24 (permalink)
Old 04-04-2013, 06:08 PM
Wiki Edits: 11
I got ahead of myself again...Heres what I did today...
Started working and realized the reason I couldnt find anything I was looking for is because I've made such a mess,I put everything in the box except for what I needed ...I got the inner rocker and pillar primed and welded the hinge support in place ,if the support is off even a little the door wont fit...primed that too and started welding the rocker on...
ID:	72924   Click image for larger version
ID:	72925   Click image for larger version
ID:	72926   Click image for larger version
ID:	72927   Click image for larger version
  #25 (permalink)
Old 04-04-2013, 06:15 PM
Wiki Edits: 11
At the begining of the thread I explained that I didnt want holes in the outer rocker from from drilling out the welds because I wanted to weld them on from the backside heres why...just a slight burn spot that needs very little prep and NO grinding which saves a ton of time plus its not only faster it looks better,in my opinion....
Tomorrow I hang the door....If it fits
ID:	72929   Click image for larger version
  #26 (permalink)
Old 04-04-2013, 10:56 PM
put up or shut up
yep. Did the same on the last rocker I did, which was a nomad. Was worried on that one cause no support to mock up fenders. nothing a little slice in the rockers can't handle. Great work!
I know that feeling. The same feeling I got when I welded in a hinge pocket on a chevy truck. Someone on line told me it was fine to do with no bracing and like a dummy I listened. Soon as I cut that thing out it was like the titanic. I had to measure the other side on top of all my bolt hole measurements and STILL was worrying at home before the weld in.
  #27 (permalink)
Old 04-05-2013, 07:52 PM
Wiki Edits: 11
This morning I did a trail fit of the door and it fit pretty good I got a nice even gap from the rocker and door bottom and a nice even gap at the door to 1/4, I can deffinetly work with that...I bocked the guide coat to make the body line stand out so I could see how the bodylines lined up and they looked good too but HOLY CRAP the 1/4 and door are a lot rougher than I thought...Now I'm thinking I want to replace them too...Not wanting to look at it for a while I hung the fender To see how it fit ,I dont want any more surprizes... It fit really well but needs a little work on the bottom....
Anyway for a trial fit I'm very happy with the gaps and now I can take it all back apart and finish my welding,I'll use that time weighing out whether or not to replace the 1/4 and door ,I'm thinking I will...40.00 ea at the pull it yard ,at least I can go there tomorrow and see what kind of shape they're in....
ID:	72941   Click image for larger version
ID:	72942   Click image for larger version
ID:	72943   Click image for larger version
  #28 (permalink)
Old 04-06-2013, 09:12 AM
put up or shut up
that door looks pretty hammered as if the body line is pushed in? That would be the final straw for me on that door if so. If the new one lines up the same why not give the door a little lift w/ a jack in the back when no one's looking to raise the body line? With the welded in hinges you probably don't have much choice. Great job btw. Never had to weld in a pillar holding in a welded on hinge but I can see the importance of it having to be perfectly placed. Great work, as always.
  #29 (permalink)
Old 04-06-2013, 01:16 PM
Wiki Edits: 11
It looks decieving the actual damage at the bottom body line is in the 1/4 ,hard to tell from a pic but the center body line is nice ,lifting the door would line up the bottom line but throw off the center line...even the the jamb of the 1/4 is twisted and buckled,thats why I'm thinking of replacing the 1/4 ...the damage to the door is strictly cosmetic and confined solely to the skin...
My thinking at this point is do it up right...replace the 1/4 and door with good quality used parts and no filler work...The door is a no brainer ,replace it, for 40.00theres no way I can use filler and beat that,Thats only 1 hr to do the filler work and dont buy any material thats just labor.
I figure the 1/4 would take 8hrs to get straight with filler,thats 300.00 in labor PLUS materials so again 40.00 for a 1/4 ,5hrs to replace it 3 to remove the old one its still way cheaper to do it right ....Thats IF I can get the good,premo parts no sence getting junk thats almost as bad as what I got (I'll have to take my time and check them out good) ,,,Well,I'm off to the U Pull yard...
  #30 (permalink)
Old 04-06-2013, 09:10 PM
cyclopsblown34's Avatar
Colorsanding painter
Excellent work and write up Michel.
Unibody cars? 39chevy Body - Exterior 1 08-19-2008 06:53 PM
replacing pressed rocker stud with threaded stud DHMag Engine 16 09-06-2007 04:57 PM
replacing a front unibody frame with a tube frame ? (bit long) lowROLLERchevy General Rodding Tech 5 04-06-2007 09:49 PM
unibody damage yeepman2 Body - Exterior 5 11-07-2006 05:21 PM
unibody nameless General Rodding Tech 2 06-15-2003 02:24 PM
