Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Replacing Door Panel Boards
Old 06-20-2011, 09:35 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Here are the pictures of closing and flattening the punched holes in the steel. The hole in the last picture is a positioning hole drilled in the steel from the factory and also in the new panel. There are two positioning holes. That picture also shows the punchings closed and flattened. To attach the two pieces together, you just spray contact adhesive on both parts, mate up the positioning holes and press the two parts together with the panel on the inside of the steel piece.
ID:	56216   Click image for larger version
ID:	56217   Click image for larger version
ID:	56218   Click image for larger version
ID:	56219   Click image for larger version
The Following User Says Thank You to DanTwoLakes For This Useful Post:
Navy LDO (03-31-2014)
