Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Replacing Door Panel Boards
Old 06-20-2011, 08:56 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
The first picture shows the two positioning holes that I circled with a magic marker. The next step is to glue down the padding over the steel strip, and glue the new vinyl of the new panel to the back side of the steel strip and the new door panel. The last things to do are to put back the chrome ferrule and attach the new weatherstripping. I attach the new weatherstripping with stainless steel pop rivets. You can attach them with staples, pop rivets, or small screws, but the pop rivets are the easiest and also seem to hold the best. Here are the finished panels.
ID:	56224   Click image for larger version
ID:	56225   Click image for larger version
ID:	56226   Click image for larger version
ID:	56227   Click image for larger version
The Following User Says Thank You to DanTwoLakes For This Useful Post:
Navy LDO (03-31-2014)
