-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   replacing factory in dash oil gauge with aftermarket gauge (http://www.hotrodders.com/forum/replacing-factory-dash-oil-gauge-aftermarket-gauge-183701.html)
Torque454 09-01-2010 03:48 PM
In my 79 c-10 pickup I have an electronic oil pressure gauge that is not working. I have made sure that the sending unit is good and that the wiring is all hooked up but the needle is stuck 2/3rds of the way across the gauge and doesn't move, ever. I need an oil pressure gauge. Is that factory gauge removable so I can add an aftermarket gauge in its place?
Bryan59EC 09-01-2010 06:22 PM
Go to your local Chevrolet store and get a new gage
There are 2 different gages for these trucks
0-60
0-100 ( I think)
The sending unit must match the gage
Would not hurt to get a gage and a sending unit at the same time.
Should give you another 20-30 yrs service
I had to replace both of mine in 2001-----oil pressure dropped to 0 and stayed there for about 2 weeks-----apparently not an engine issue.
DanTwoLakes 09-01-2010 07:23 PM
Let's put this in General Rodding Tech.
Dan
75gmck25 09-06-2010 01:34 PM
LMCTruck.com also has the gauges in their catalog, and there are plenty of trucks in the junkyard that have the same instrument panel. Just make sure you are looking at the ones with an electrical oil pressure gauge. Early models (73-76?) had a mechanical oil pressure gauge.
Bruce
