Replacing front universal joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2004, 06:43 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
How do you change the front u-joints in an '84 Chevy 4x4? I've got a non greaseable front u-joint that appears to have a little slop in in cap. I've never changed a front joint in this type of application and don't have a real clue as to how to totally change it. This truck has lock out hubs and I have had all the brake stuff off down to the backing plate. Am I going to need to pull the axle shaft from the center out? Or could I just knock the ball joints out and leave the center shaft in? Thanks in advance.
Chet
Old 11-28-2004, 08:55 AM
poncho62's Avatar
Wiki Edits: 5
You need to pull the housing off that surrounds the axle. It bolts to the spindle with about 8 nuts. Once you get this off, the whole axle will pull out.
You do have the rotor off, right? If not, you need a spexcial socket to get the bearing nut off. I made one from a piece of pipe.
It's been 10 years since I did one of these, so I may have missed something.
I managed to fit "U" joints in there with grease nipples, but they are not easy to get at.
