I would like to replace a burned headlight bulb for
a 1995 camry.
I bought the bulb.
I could not pull out the headlights in order to change the bulb.
I don't have the service manual for the car.
Could you tell me what exactly I should do to replace the bulb
Thanks
i have never changed one on that car but they are all about the same.
if you can get to it easy, just unplug the wires from the back of the bulb, there sould be a plastic (?) thing holding in the bulb-- just turn it to the left, pull it out along with the bulb and put in the new one, making sure that it is flush in the knoches.
note: do not touch the new bulb. the oils from your skin can distroy it.
akm is correct, most late model cars you do not remove the headlamp assembly. The bulb is removed from the rear of the headlamp after you unplug the harness connector.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
