Replacing a headliner... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 12:35 PM
I have the headliner out, brushed off all of the old crusty foam. I am left with a tacky film on the fiberboard. I will be using Weldwood Landau top headlining spray... Should it be safe to go over the tacky stuff? Ive tried using Xylol(recommended for weldwood), acetone.. And nothing gets the stuff off.
Old 06-15-2013, 12:49 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Acetone will not touch contact adhesive, either use Xylol or mineral spirits, nothing else. Xylol and mineral spirits are almost the same. Xylol is better, but more expensive. You can spray the top and trim adhesive right over the old stuff on the car. It will still work fine. Just clean the area with alcohol first.
The Following User Says Thank You to DanTwoLakes For This Useful Post:
mike8668 (07-19-2013)
Old 06-15-2013, 01:20 PM
Thanks Dan
Ive done 2 others using professional products rattle can adhesive, but I figured this next one I will just buy a gallon of Weldwood and a spray gun. Its out of a BMW 740 and I probably saved money doing it this way vs 13 bucks a can.. Had to stretch out my last rattle can much further than I wanted to.. The heat here in Florida is just a bear on the headliners..They are my personal vehicles and while not perfect, they look 100% better than before...
Mike
Old 07-19-2013, 05:34 PM
Thanks Dan update: photo posted
This is just a quick before and after of c pillar and rear speaker box. Not perfect but for a newbie... Im happy. Also did headliner and all other trim panels and STILL have a half gallon adhesive left....Looking for things to join.....
Name:	c pillar before and after.jpg
Old 07-19-2013, 06:36 PM
Banned
rattle can will fail in a month or two of heat!! glad you are doing it right!!!
Headliner PAS55 Interior 3 10-26-2006 07:38 AM
headliner prstlk Engine 1 12-28-2004 08:07 PM
How to do a headliner RickB1B Interior 5 12-28-2004 08:37 AM
new headliner docs57 Interior 6 12-26-2003 09:48 AM
headliner dave76 Interior 6 01-15-2003 06:13 AM
