Replacing Oil Pump in a '65 Ford 302 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2012, 03:00 PM
Has anybody replaced the oil pump in an early model '65 ford mustang 302. This motor is in my shoe box 51 ford. Is it as simple as dropping the pan, removing the old and installing the new with the two bolts? Thanks again.
Doug
Old 09-11-2012, 06:51 PM
It shouldn"t take much more than you described. It has been 5 or so years sience I did a 302 but I don't remember and detailed specifics other than remove pan, remove oil pump, replace pump, replace pan.
Old 09-11-2012, 07:51 PM
poncho62's Avatar
Wiki Edits: 5
Ford didnt make a 302 until 1968
Ontario Rodders
Old 09-11-2012, 08:23 PM
I know that
Well I figured you did a transplant with the 302CID I was just in talking 302 in general.yes I was gotten LOL
Old 09-12-2012, 02:15 AM
JeffB's Avatar
289-302 is the same,however before you pull it bring it up to #1 TDC . Then when you lower the old oil pump the driveshaft will come with it,note how it was installed you will see a clip.Always install a new pump shaft with the pump they are a SBF weak link,part number is a Melling 68-S about $10 at Autozone.The reason I am telling you to remove it with the shaft is it will be easier to line up the pump driveshaft to the distributor.
Old 09-12-2012, 10:38 AM
oil pmp 302
Hey JeffB, thanks for the heads up with the inside info about the shaft and the TDC alignment. If you ever get to Cruisin The Coast in October on the Mississippi Gulf Coast, (coming up in two weeks) get in touch. Sweet looking 302 in your pictures, love the Merc. Later.
Doug d.
shoeboxford51
The Following User Says Thank You to shoeboxford51 For This Useful Post:
JeffB (09-12-2012)
Oil pumps for ford 302 Torque454 Engine 10 02-16-2012 01:27 AM
Ford 302 Water Pump/timing Cover 65ELCMO Engine 11 12-30-2011 07:56 PM
302 ford crankshaft oil slinger dave4943 Engine 2 11-20-2006 07:52 PM
Oil Pan Question - Ford 302 30Coupe30 Engine 1 06-18-2006 02:31 PM
oil pump 302 351w nitrous_69stang Engine 1 11-27-2004 02:23 AM
