Replacing old brake lines on 1946 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2006, 04:38 PM
Hello
I'm looking for some help or information on bending and flaring of stainless steel brake line. This is my first attempt and I'm looking for any useful hints as well as what tools will be required.
Thanks
Old 03-31-2006, 05:25 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders....this forum is for introductions not questions. Please look in the KnowlegeBase or do a search on this site for the info you are looking for. If that fails to find it then place your question in the Suspension/Brakes forum.
Old 03-31-2006, 05:29 PM
Wiki Edits: 49
Just so you'll know. Stainless lines require a 37* single flare which is totally different than normal soft steel lines so you'll need a special tool for the flares. Do not attempt to double flare stainless lines because they'll split.
Old 03-31-2006, 05:35 PM
Race The Truck
Last journal entry: Son's Truck
I know doing stainless uses different tools. You would normally would use. I know you can get them at the auto tool supply. I know the bend process is the same.
Craig
Old 03-31-2006, 06:46 PM
poncho62's Avatar
Wiki Edits: 5
moving to brake forum.
Replacing a heat and airconditioning blower in a 93 Chevy truck 4 wheel drive hsanche General Rodding Tech 1 02-05-2005 07:05 PM
Brake lines C10 wickedwitchinak Suspension - Brakes - Steering 4 08-07-2004 07:04 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 12:16 PM
