if your not taking the head off for machining just order one from a 1970 z28 with the lt1 it is a straight stud without the hex, thus negating the need to machine down the stud boss.Just tap the hole 7/16 n.c. you can get a tool for this for about $15.00 it also doubles as a puller to remove the stock press in stud.
I wonder what caused the rocker to cut into the stud in the first place. It seems to me that a misaligned stud (cocked off to the side instead of straight up & down) might cause that, and if so, installing a new stud into the same misaligned hole would probably end up the same. Unless the old stud was just bent.
the rocker had a divot in it, like it may have been dropped by someone. it flat spotted the slot just so much to cause it to cut into the stud. i didnt see it when i installed them over a year ago. the stud itself is A-OK as far as alignment. |
As for why this one rocker gouged the stud, you need to look at alignments. A bent stud could do this, rockers that have insufficient length in the slot is another. A change in cam lift or a change from 1.5 to 1.6 rockers can affect pushrod length which then affects alignment of the slot in regard to location of the stud. This can also be the result of over revving the engine or tiring springs that are allowing the valve to be out of position with regard to the rocker arm position. Tapping for screw in studs makes a lot of chips. You want to surround each location that's being tapped with wheel bearing grease as well as the tap to insure that chips are trapped and can be wiped up. you will want to remove the tap frequently to clean the chips and regrease it. And yes you need the alignment tool and two taps, a taper end tap to insure you're going straight when getting started and a bottoming tap to insure that you have full depth threads cut all the way through just incase the taper tap hits something in the water jack before if cuts a complete set of threads. Bogie |
tom |
tom, ill be pulling the intake so i can monitor the escape routes of the chips from tapping. more than likely, ill stick a magnet in the valley to collect the chips as they fall.
oldbogie, i already attempted to describe what caused the rocker stud to become gouged, perhaps i wasnt clear enough. i tried to get a good picture of it but its difficult to do. the slot is not oval like it should be on a normal rocker. the slot of this rocker resembles a kidney bean. |
I just went to the local parts house and got them for a 1970 camaro z-28, I know speedway motors sells them also.www.speedwaymotors.com
They're available as a set from Summit (Mr. Gasket parts) or may be available from a local NAPA or other good quality parts house.
http://store.summitracing.com/partde...5&autoview=sku Or, you may be able to purchase one only from your local Chevy dealer parts department. I'm sure they've had to deal with this problem more than once. |
| Broken rocker stud, why two breaks? | RAW | Engine | 20 | 07-17-2011 06:33 PM |
| Pulled rocker stud, and more? :( | Gokussj5okazu | Engine | 17 | 03-22-2007 04:53 PM |
| Threaded vs Pressed Rocker Studs (SBC) | pgtr | Engine | 7 | 10-29-2004 07:10 PM |
| pontiac 389 broken rocker stud | tree_entz | Engine | 4 | 06-08-2004 12:29 PM |
| Pressed in rocker stud problems | zin | Hotrodders' Lounge | 7 | 06-01-2002 08:21 PM |
