Replacing rack & pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 07:10 AM
Hey Guys,
I'm replacing the rack & pinion on a Chrysler LeBaron coupe with
a 2.5 engine, 1989. Is it necessary to lower the front cross
member in order to remove the old rack? Having a tough time
trying to loosen the power steering oil lines.
Thanks for your help. George
Old 08-22-2006, 05:59 PM
HOPE you got it figured out ...
Not many 1989 LeBaron owners on Hotrodders.com
But you never know until you ask ...
Deuce ... Moderator
Old 08-23-2006, 09:42 AM
It is not necessary to lower the crossmember, but it will definitely make your life easier. The power steering lines are tough, but the real problem will be getting the rack out. The area between the body and the cross member in the area of the rear crossmember mount is just slightly smaller than the height of the input shaft on the rack. A certain amount of twisting and turning of the rack will get it out, though it seems to be more luck than skill. Lowering the crossmember will not only make getting the rack in and out physically easier, it will make it much easier to line up the steering shaft on install, which in my experience is a humongous pain.
Edit - My mistake, didn't check the date. Hope you got it figured out.
Old 08-23-2006, 09:43 AM
Double post
Old 08-24-2006, 07:13 AM
Rack & Pinion removal.
Slowturbo,
Thanks for your suggestion, but I already lowered the front
cross member. You're right, it will be much easier to assemble
the new stuff.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 11:24 AM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 08:58 AM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 01:53 PM
Mustnag II rack and pinion Echofive Suspension - Brakes - Steering 3 05-26-2004 07:26 PM
