Replacing rear 1/4's - Difficulty? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2003, 11:43 AM
CET's Avatar
CET CET is offline
il enforcer
Post Replacing rear 1/4's - Difficulty?
I have the opportunity to purchase a 68 Firebird for dirt cheap but it NEEDS rear 1/4's among other things. I have done some bodywork in the past and I own a Mig welder and know how to weld fairly well.
Is panel replacment something that one should attempt if they have no experience or should I just find another car that is not cancered out?
Old 01-16-2003, 12:30 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
1/4 panels are pretty simple to put on. Its alot of work and you may need a set of exstra hands to help out with alighning, but its nothing that is to incredibly hard. Most anyone with minimal panel repair exsperience can do it, just go slow, measure carefully and alighn those boylines! If you need more help feel free to ask, happy to help.
HK
Old 01-16-2003, 02:43 PM
dinger's Avatar
Post
Before you get started on a project like this, check your inner fenders, inside trunk, anywhere those panels connect to the original body. If there is a lot of rust or damage there be prepared for a lot more work. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 01-16-2003, 02:48 PM
CET's Avatar
CET CET is offline
il enforcer
Post
Thanks for the tips Guys.
The rest of the car has minimal rust but you never know what I might find when I cut the 1/4's off.
Old 01-16-2003, 03:39 PM
Location: 4839 university ave ne. columbia hgts mn. 55421
Post
For sure check all connecting panels. Also check for prior damage not repaired well these thing can make a simple job a nightmare.
Old 01-17-2003, 08:01 PM
Post
Just some humble suggestions.
First, do not cut anything out until you get the replacement panel in your hands...no matter what!(I have some stories for this).
Next, align the doors and trunk lid because these will become your points of reference when that replacement panel doesn't fit right.
Try to get the full factory replacement panel...not the skin. You can cut out the majority of the quarter with a cutoff or sawzall but I highly recommended drilling out the factory spot welds to remove the old quarter. Then use the same technique to put it back on(except for the A piller). I'm on my third quarter so, no you don't need much experience, Just patience. My first quarter was a '67 Mustang coupe and it came out absolutely perfect.
Hope it helps.
jim
Old 01-18-2003, 03:02 PM
CET's Avatar
CET CET is offline
il enforcer
Post
Thanks for the excellent information. Cutting it off and then not finding a replacement would suck about as much as still being married to my 1St. wife.
Old 01-18-2003, 03:16 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Old 01-18-2003, 05:52 PM
Post
It's not so much finding a replacement as it is thinking the quarter covered a larger area in the pictures you see before you buy it...Yikes!
I'm putting on the passenger side quarter on the '55 chev tomorrow, wish me luck.
jim
Old 01-19-2003, 06:29 AM
CET's Avatar
CET CET is offline
il enforcer
Post
Good luck jc55.
