Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Replacing Rear End (Choices)
Old 05-26-2002, 08:26 PM
wrenchturner wrenchturner is offline
Post
Ford 9 inch If Im not mistakin 57 ford housing is 51 inches I shoved one under a vega which was 2 inches wider than the vega which was 49 inches (compensate with off set wheels)wrenchturner P.S leaf spring housing cut off brackets added chev.stock brackets coil spring
[ May 26, 2002: Message edited by: wrenchturner ]</p>
