replacing rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2007, 12:36 PM
inquiring_mind2's Avatar
a shade tree mechanic
replacing rings
Hello,
I am replacing the rings on my bbc. I have a couple of rings that are broke. I bought a new set of moly file to fit rings. Can I save the old ones and reuse them again? The motor only has 8 passes on it. Rings are getting expensive now and if I can reuse them I will save them if not to the trash they go. Thanks for any info
Old 05-20-2007, 06:11 PM
Last journal entry: frame build
Unless there is something you are not telling us, just rering the damaged cylinders.
Old 05-20-2007, 07:31 PM
I think something eles is wrong
If youre breaking rings with only 8 passes somthing else is wrong . TOO tight something by the way which rings are you breaking. I build over 50 engines a year for racing and many aplications ive never had a ring break unless the engine has been super hot or over 250 th miles and not many oil changes somthing wrong.
Old 05-20-2007, 07:36 PM
BOBCRMAN@aol.com's Avatar
Back in the day. I used to replace only the top ring at re-fresh time on my drag car. Worked very well.
Old 05-21-2007, 12:09 AM
replacing rings
Ok I should have said this from the beginning. My bad. I had gotten water in the motor and I ruined the crank and most of the bearings. Come to find out the valve guides were bad. But that is another story. so I took the motor apart. When I was inspecting everything and I was having the new rods put onto the pistons I noticed some of the top rings and been broken. I would assume it was from the metal shavings that were in the motor from the crank and the rod bearings. I had metal shavings all through the motor. They were not to tight or nothing like that. I pulled each one off the piston and I put it back into the correct cylinder and I measured them to see if they were still with in specs and they were. So Thats why I am asking if I can reuse them or not?
Old 05-21-2007, 12:42 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Did you cut the ring ridge out with a ring ridge reamer?
IF not that is why you are breaking rings..
Every time you pass a ring over the ridge taking it out, it will crack the ring if the ridge is large enough..
ALSO be sure your not trying to put STD rings on a 10,20 or 30 over piston..look on the wrist pin deck, it will say STD..or 10,20,or 30 right on the deck.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-21-2007, 01:37 AM
there is no rig there I cut what was there out. I also made sure I got the correct set of rings too
piston rings please help 67RS-Groundpounder- Engine 6 02-08-2009 09:15 PM
Replacing rings from underneath JG700 Engine 9 05-18-2007 05:56 AM
piston rings to use on a rering job grumpysdeuce Engine 4 11-26-2006 09:06 PM
Need More Info On Piston Rings Canadian Charlie Engine 1 02-25-2006 06:00 PM
piston rings crshrmn3 Engine 3 09-27-2002 12:06 PM
