Replacing rockers and pushrods question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2004, 02:05 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I have a set of new rocker arms and push rods on the way that I'm going to be installing on the 400 sbc. I can't seem to find a source for Torco MPZ that I used to use, so I picked up a tube of assm lube from stay lube. I've never used this stuff before does it stay put well? also I want to pre lube the rockers and pushrods before I install them on the block, how much do I use and will I need to change the oil right away after I get it running?
Do I need to lube both ends of the pushrods or just the rocker arm/ pushrod connection?
Regards
Mark
Old 06-04-2004, 02:58 PM
Torco is available from the manufacturer in Sante Fe Springs.
