My 400 small block has a stock cast crank, it has been cut 20/20 before I got it and I am wondering if I should even bother with messing with the usual modifications on the stock short rods? The rods have stock bolts in them and I am tempted to go with some arp bolts but Iwould think that the rods may need remachining if rod bolts are pressed off? This engine has an older design cam with solids a crane zip .510 and does pull to a self imposed redline of 5800, should I button it back together as is? It is apart just for a new oil pan with a windage tray and the finish on the crank and bearings looks good as is. any ideas? and is this max safe rpm for this set up?
ARP bolts are good insurance, yes you have to get the rods reconned if you change the bolts. These rods with good bolts are usually safe to 6500-7000 rpm.
Thanx Bob , My hesitation is that I have seen some sorry rod rebuilders out there where they want to resize rods but only surface the cap side (probably cause they did not want to pull bolts) In any event your advise and knowledge are greatly appreciated I am sure wondering if the short chevy 400 rods would live past 6000 for any amount of time due to the rod angle. PS do you run a machine shop??? feel free to pm me thanx..
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
