replacing the side windows on a 1960 pick up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2011, 12:35 PM
I am replacing the side windows on a 1960 pick up. how do you remove and replce the chrome piece around the window glass?
Old 03-29-2011, 01:04 PM
302 Z28's Avatar
The chrome channel is held in place with window tape. You must very carefully pry it off. Reassemble it with a new glass and some new window tape and carefully tap with a rubber mallet around the frame until it is fully seated. A little water and soap will make it a little easier.
Vince
Old 03-29-2011, 01:15 PM
window
thank you very much for your help,Vince.
Lowering a 1960 Ford Pick up rushlow Suspension - Brakes - Steering 2 11-14-2011 11:27 PM
Replacing Vent Windows Riverman Body - Exterior 6 09-29-2005 08:11 PM
cleaning side windows calimstng66 Body - Exterior 0 07-21-2004 12:21 AM
one piece side windows murraydavidson Body - Exterior 4 08-14-2003 06:59 PM
55 Chevy Nomad side windows Nomad Jack Body - Exterior 3 03-12-2003 08:22 AM
