Replacing the stock B30 torque converter in a 4L60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2011, 12:29 PM
old yukon's Avatar
Would there be a problem replacing the stock B30 torque converter (30 spline and 12 inch diameter) with a B-85 (30 spline and 12.5 inch diameter) torque converter in a 4L60e ?
Old 02-15-2011, 06:13 PM
vetteman2's Avatar
whats the stall speed on both?
Old 02-15-2011, 09:04 PM
old yukon's Avatar
i could not find the stall speed for either the B30 or the B85.
From what i could remember the B30 had a stall speed of around 2000prms.
I was told the B85 would swap straight over (click image). but I am not sure now.
Its larger, i don't know if that is a problem in terms of torque, and bolt on hole location
I don't know the clutch type, perhaps it will not match the pump.
My original torque converter had the following:
on a sticker - TMBX 2420
6642
then printed - 035 - 00-16:07-N
then stamped on the side - 0947 -B
If anyone here understands the world of torque converters, i would appreciate some assistance here.
Thanks in advance
Old 02-16-2011, 08:54 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
If you don't know the difference in stalls I wouldn't swap it, I have a convertor from a late model 4.3 s10 that is suppose to be about the highest stock stall, Only reason I would change it out is I know where it came from and what the stall is.
Old 02-16-2011, 02:29 PM
SSedan64's Avatar
I found:
B-29= 1211-2000rpm stall.
B-30= 1211rpm stall 6-Lug Diesel.
B-85LP & LW= 1400rpm stall, same as TMBX code.
B-85= 1400-1600rpm stall, 2 clutch material types.
Page 7 >> http://www.transparts.ru/pdf/tc_gm_03_web.pdf
Old 02-16-2011, 10:25 PM
old yukon's Avatar
Thanks SSedan64 for that.
Just correcting an error of mine. it is a B29 not a B30
So from what you found: B-29= 1211-2000rpm stall speed.
and
B-85LP & LW= 1400rpm stall speed B-85= 1400-1600rpm stall speed
Is their a problem with the slight variation in stall speeds or not?
Old 02-17-2011, 06:07 AM
SSedan64's Avatar
Shouldn't be any problem, it's only 200rpm difference between the 2.
Todd
Old 02-17-2011, 11:25 AM
old yukon's Avatar
The B 85 will not go on the same 4l60e set up i have, it needs a longer shaft. so i have to say with the B 29.
And I was told the bell housing is also different in the trannies with the B 85.
Old 02-18-2011, 01:45 AM
SSedan64's Avatar
I think the B-85 fits the LS type Engine and that Trans also has the bolt on Bellhousing.
4l60e torque converter locked acdcontheroad Transmission - Rearend 2 09-14-2010 07:35 PM
4L60E torque converter won't unlock acdcontheroad Transmission - Rearend 2 09-12-2010 06:23 PM
2000 Trans Am WS6 4L60E stock torque converter GMCTRUCKS Transmission - Rearend 2 07-21-2010 07:59 PM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
4L60e torque converter check? fiolater Transmission - Rearend 4 03-23-2008 01:26 PM
