Replacing tack strips\what to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2005, 08:25 PM
Stroker56's Avatar
I need to replace the tack strips on the interior of my 56 chev . They look and feel like a very hard cardboard. I did find some on the Luttys chev site
but thought I could make my own.
Anyone out there fab your own ? Any ideas what can be used?
Old 10-14-2005, 12:51 AM
willys36@aol.com's Avatar
Wiki Edits: 21
The ones in my '36 Willys were cardboard that totally deteriorated and just flaked out of the channels. I made replacements using thin strips of cherry wood (~1/2" wide by 1/16" thick). I laid layers of the cherry in the channels with generous amounts of yellow carpenter's glue until the thickness built up to ~1/2". The thin strips bent easily to the shape of the curved channels. Taped them down with blue masking tape until dry then attached them permanently with counter sunk, #4,sheet metal, phillips flat head screws into the sheet metal channel every 6" or so.
tack hook up 2000 chev 3500 van cliff tate Electrical 2 03-13-2005 11:13 AM
First time replacing a trunk bigfred1958 Body - Exterior 0 08-30-2004 12:10 PM
Please help with opinions on replacing Camaro rear subframe rails RPB-71' Camaro Body - Exterior 3 09-19-2003 07:33 PM
2nd post didnt tack on ianhealey Hotrodders Site Suggestions and Help 2 09-13-2003 11:25 PM
replacing valve springs stfinney Engine 8 09-06-2003 11:46 PM
