replacing water pump - do the timing chain too? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2006, 11:43 AM
dbuff's Avatar
67 olds cutlass w/ stock 330
Not real mechanically inclined so shop is replacing water pump - should i get timing chain done as well?
how much cost to do a timing chain is reasonable? after they dismatle it to do the pump , what needs to be done? pull and replace chain and cover, reset timing? just curious how involved it is.
many thanks.
Old 05-22-2006, 01:22 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Does it need one?
If not the leave that up to the mechanic.
Old 05-22-2006, 01:29 PM
dbuff's Avatar
not sure if needs it , had car for 20 years - was daily driver for 5 of those.
how to know if needs one? i thought chains were either good or bad and you didnt want to take a chance on it breaking and damaging engine?
Old 05-22-2006, 01:35 PM
you are already in the neighborhood......new chain & gears. Might as well hang a fuel pump on it as well.
just my .02
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
where's the water pump?? mikeweyman Engine 9 07-05-2004 05:34 AM
Update on Hi-Flow water pump Kaylah General Rodding Tech 7 10-25-2003 11:12 AM
windsor water pump FAIRLANE DUDE Engine 2 05-29-2003 03:30 AM
windsor water pump FAIRLANE DUDE Engine 0 05-28-2003 07:45 PM
