replacing weather striping on door - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2005, 07:39 PM
I have attached some pictures od the doors on my 8 that need some work done. My question is does anyone know where i can find some detailed illistrations showing how to replace the rotted weather striping on the out side in the picture. I also zoomed in on the crack that all jeeps inhernetly have. i thought i would weld up this crack and grind it smooth. I will also add a 18 gauge plate on the inside for renforcement to try to stop this from happeneng again...any thoughts?
thanks SC
ID:	5386   Click image for larger version
Name:	weather striping.jpg
Old 06-17-2005, 09:57 AM
sedan delivery's Avatar
weather strips
jcwhitney.com has weather strips for a lot of older cars. just type year make and model after you search for weather strips. i dont have any how to's on doing this.. most of the time is straight forward. check car lots for the same veh. and take a look at how they are installed. some are peel and stick flat weather strips and some are clip on.. some are glue on.
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
