replacing wood body structure in the '29 dodge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2006, 10:16 AM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
So the wood structure in the body of the '29 dodge is pretty useless, is it best to replace it with wood again?
I like metal, but wonder if there is a reason not to 'upgrade'.
Oh the car is going to be chopped and channeled so origionality is not an issue.
I have looked in the archives, but didn't see anything.
Keith
Old 02-16-2006, 08:01 PM
30desoto's Avatar
Dodge ain't all bad
427v8
Wood does not have to be replaced with wood, it is good if the wood you have is in good enough shape to use as a template to make metal fit. Metal in my opinion is better and stronger.
30dee
Old 02-16-2006, 08:09 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A lot of the guys use square steel tubing.
Old 02-16-2006, 08:41 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
It is quite a task to do that..the tubing can be formed to fit the curves of the body and use some larger sections at the door jambs to recieve the hinges and bear claws..
Use small section like 3/4x3/4 for frames and bend them to suit and then cut the pieces for door jambs either with a plasma cutter to suit or your bandsaw in the vertical position..Probably a good idea to strip your body panels and prime them as you go..
Takes a bit of planning and thinking before starting on this kind of project..
OMT
Old 02-16-2006, 11:22 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
dantech is building a 28 Dodge. In a few of the pictures you can see how he used tubing to strengthen his body.
http://www.geocities.com/dantechfab/page11.html
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-17-2006, 02:17 AM
kristkustoms's Avatar
First name...............Shawn
your upholstery man will hate you for leaving him no wood. if you are paying someone to do the interior, plan on spending another 500 in having him add wood back in on top of the steel to be used as "tack" strips. at least leave some room for 3/16 to 1/4 inch pieces of wood to be added later.
Old 02-17-2006, 08:34 AM
427v8's Avatar
Wiki Edits: 7
Thanks for the replies,
Sounds like a combination of wood and metal might be a good idea.
I've seen Dantechs car, he's an artist! But the dodge Bros club guys sure hate him, LOL
1934 Chevy (Replacing Wood With Steel) QUESTIONS mistermuscles Body - Exterior 7 05-12-2011 12:05 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 01:04 PM
Looking for info on interchange of 1950 f2 truck body to 1986 3/4 dodge extended van Ken Cunningham Introduce Yourself 7 07-23-2004 09:28 AM
body wood vanetta Interior 2 07-20-2002 04:53 AM
