Required Vacuum Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2008, 09:44 PM
Hello I bought a 454 that was taken out of an 86 one ton truck. I have gone through the majority of it to check things out before I install it in my car but ran into a problem with the vacuum lines. I guess when the guy took it out of the truck he just started pulling everything off so i have no idea where all the line go. I have a Chilton manual but it shows the diagram for an engine with a smog pump. Since I'm not running all the emissions I need to know what is necessary for the engine to run properly. I know i need to hook up the brake booster, pcv line and an ingition advace line, are there any others I have to have. Also is it ok to hook the ignition advance directly to a manifold vacuum source or does it need to be regulated by the carb. Any help would be greatly apreciated Thanks in advance for any replies
Old 10-07-2008, 09:52 PM
Jmark's Avatar
You pretty much have it covered. All I can add is if your intake has an EGR valve, that will need to be run through a temp switch, usually screwed into the thermostat housing.
You may also need a "manifold source" hose for any under dash heater/A/C controls.
You may also need a manifold vac line to the trans, if it has a modulator.
The vac advance can go either way, manifold or secondary, depending on who you ask.
Mark
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 06:10 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
!!vacuum lines!! Tryin2MakeIt Engine 1 11-02-2007 02:31 AM
68 charger lights T-bucket23 Electrical 5 08-14-2006 06:07 PM
Should i replace old vacuum lines? Rubberman2003 Engine 6 01-10-2005 12:28 AM
