Residual Check Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 07:15 PM
I'm done with the front disc brake conversion on my 70 El Camino except the the brake lines I was planing to order from Inline Tube.Do I need to run a residual check valve along the new disc drum proportioning valve at the master cylinder.
Old 01-29-2011, 07:24 PM
machinist & fabricator
residual valves are for brake systems where the master cylinder is lower than the wheel cylinder or caliper. they stop the fluid from leaking back into the master cylinder
all you need is the proportioning valve for the disc brakes, and you are good.
if its all in the stock location.
Old 01-30-2011, 10:09 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
A 10lb residual pressure check valve is required for all axles that have drum brakes regardless of the mounting position of the master cylinder. The valve holds pressure against the seals in the wheel cylinders and keeps the return springs on the brake shoes from retracting the shoes too much when you release the brake pedal.
You may have one already in your proportioning valve or in your master cylinder.
Andy
Residual Pressure Valve BEFORE or AFTER Prop. Valve? matt2491 Suspension - Brakes - Steering 13 10-16-2010 03:51 PM
Residual check valves Migman Suspension - Brakes - Steering 20 03-09-2010 10:27 PM
Residual valve question Crazy Mopar Guy Suspension - Brakes - Steering 5 12-17-2003 12:58 PM
gm residual valve oldcarguy85 Suspension - Brakes - Steering 1 02-09-2002 02:30 AM
