Residual check valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2010, 07:49 PM
Read a tech article on using 10psi RCV's on rear disk system when using Caddy E-brake calipers. The 10psi valve is supposed to give less pedal travel. Has anyone ever tried this?
Old 03-04-2010, 08:13 PM
65ELCMO's Avatar
disc uses a 2 lb check valve. 10 lb is for drum brakes
Old 03-04-2010, 09:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If your master cylinder is mounted below the calipers, you need a residual pressure valve. They are not needed if your master is on the firewall.
But the above 2 pound spec is correct- if it is needed.
Now, you mention these calipers specifically- there could be a reason for it w/them that is out of the ordinary.
Old 03-04-2010, 10:14 PM
I am referring to the use of 10psi RCV on the Caddy calipers specifically. They are noted for causing a long pedal travel especially if the parking brake is not used frequently to keep the piston ratcheted out. They are also know to be very difficult to bleed.
Old 03-05-2010, 08:34 AM
Frisco's Avatar
Glad To Be Here
They are no more difficult to bleed than any other disc brake calipers.
They do have to be adjusted correctly to work well and that procedure is more time consuming. Once done though it will work well. The parking brake is built into the caliper and is cam operated. The use of the parking brake is what keeps the rear calipers properly adjusted.
The 10 psi residual valve is because of the longer travel of the pistons in these calipers and is to keep the calipers from retracting too far when the brake pedal has been released. These calipers retract approximately .050 with no residual valve in place as compared to front calipers that retract approximately .005. For under the floor mounted master cylinder you should also run a 2 psi residual valve for the front lines. You should also run an aftermarket adjustable regulator in the rear lines to enable you to balance the front to rear braking. The front brakes should be applied slightly before the rear. This is to prevent swapping ends if you have to use hard braking.
If manual brakes, use a 7/8"-1" bore master and a pedal ratio of 6-7:1.
If power brakes, use a 1 1/8" bore master and a pedal ratio of 4:1.
Don't waste your time with one of the small (too small) 7" single diaphragm boosters. They do not give enough boost to work well. If you must use one of the small diameter booster, then I suggest to get at least the dual diaphragm version.
I have posted info on these calipers and the proper adjustment for them on this site before. If you are unable to find that info with the SEARCH function, I can attach the info here.
Old 03-05-2010, 08:53 PM
Thanks Frisco. I needed to hear from the voice of experience re 10psi RCVs. I was concerned about dragging brakes. You're right re bleeding as long as they aren't clocked differently then stock position with bleeder screw at the top. Most of the DB conversion kits allow a variety position's making it a good idea to bleed them unmounted with the bleed screw at the top.
Old 03-06-2010, 07:57 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by Frisco
....They do have to be adjusted correctly to work well and that procedure is more time consuming. Once done though it will work well...
...Until the pads wear, then they will need adjusting again...
...The front brakes should be applied slightly before the rear. This is to prevent swapping ends if you have to use hard braking....
I believe you have this backwards, the rear brakes should apply before the front brakes, but with less pressure.
...I have posted info on these calipers and the proper adjustment for them on this site before. ...
I would NOT recommend using this system at all because of the adjustment problems. I worked for GM during this time, and personally worked on several cars that had redesigned parts installed numerous times with no real improvements. GM went to a divorced E-brake system on the Vettes a long time ago, and on everything else recently, for a reason. If you're doing a rear disc swap, it's normally for better brakes, why switch to a system that was a PITA when it was new, and never really got any better. I used a rear disc brake system from a 2000 Blazer on my S10, along with the front system from a 98 up F body, and I tell people "if you're not strapped in, I CAN make you kiss the windshield",
Old 03-06-2010, 08:10 AM
Frisco's Avatar
Glad To Be Here
There is a built in ratchet mechanism that will keep the pads adjusted correctly. HOWEVER, that only works when the parking brake is engaged/dis-engaged. That is why the factory states that the parking brake should be used when parking.
...I believe you have this backwards, the rear brakes should apply before the front brakes, but with less pressure.
Not backwards at all. Most vehicles have 60% (+) of the stopping performed by the front brakes. If the rear brakes are applied first, they will lock up and lose traction because of the weight transfer.
...I would NOT recommend using this system at all because of the adjustment problems.
I ran this system on my '30 Ford coupe. As you stated, it is/was a PITA to get to work correctly. I even had to modify the mechanical advantage of the parking brake to get it to apply enough force to get the parking brake to hold. I would NOT recommend this setup either based on my personal experience. However, for those seeking advise or opinions with this system I will offer what I have found.
Old 03-06-2010, 08:24 AM
Rickracer's Avatar
Even if the parking brake is used, it doesn't really work like it's supposed to. As I said, (in less detail), I fought with one of these systems for the better part of a year on an (83?) Camaro while working for a Chevy dealer, and tangled with a couple of Caddies during the same time period. The Camaro owner was VERY picky, and every time his pedal dropped a bit, it was back in the shop. I had those calipers apart so many times, I could do it blindfolded, all under warranty pay, which, if you ever worked for a dealer, you'd know, really SUCKS.
...Most vehicles have 60% (+) of the stopping performed by the front brakes. If the rear brakes are applied first, they will lock up and lose traction because of the weight transfer.
Agreed on the percentage, even greater on FWD cars, but that's what the metering valve does, it applies pressure to the rear brakes first, and the proportioning valve keeps the pressure from exceeding rear traction. Weight transfer doesn't really happen in any significant way until the front brakes apply.
Originally Posted by MPBRAKES
What does a proportioning valve do?
A proportioning valve is used in the rear to decrease the rate of pressure rise to the drums relative to the pedal force as weight is shifted to the front during braking. This prevents the rear from locking up under hard braking conditions.
What does a metering valve do?
A metering valve or "hold off valve" is used in the disc portion of a disc/drum system to hold off the application of the front discs slightly allowing the slower reacting rears to catch up. This provides rear stability on wet surfaces and reduces excessive pad wear.
The above info, and more, can be found here: http://www.mpbrakes.com/technical-su...nce-valves.cfm
I am sure that info is appreciated, for somebody that's already stuck with one of these systems, your experience and knowledge will be quite handy,
Old 03-06-2010, 03:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Actually, it appears GM has employed BOTH front-first AND rear-first schemes for brake application through the years.
Pre-combo valve brake systems could have a 'correction valve' that "was used to hold off pressure to the rear brakes so the front brakes would go on a split second before the rears." More @ http://www.inlinetube.com/Prop%20Valves/pro_valves.htm
Generally speaking, the combo valve's valving uses a rear-brakes-on-first scheme, the idea being there will be better vehicle stabilization.
Old 03-07-2010, 06:36 AM
Rickracer's Avatar
Wow, thanks Cobalt, that's the first I've heard of that, and I stand corrected,
I still think rear just slightly first is a better idea for a disc/drum system, but I don't plan to run drum brakes anymore anyway,
Old 03-07-2010, 07:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree. And drum brakes (especially fronts ) are getting to be fewer and farther between as time goes on.
Good riddance, IMHO- as (w/a few exceptions) they are labor intensive to maintain/repair, heavy and prone to fade.
Old 03-08-2010, 08:47 AM
bentwings's Avatar
bentwings
I use the Cad rear calipers with the e-brake. I had to switch them from side to side to get the bleeders in the right position and the brake levers in the right position for my cables as mounted them on top. This also required that I reverse the guts so the e-brake applied when I pulled on the handle. It was a bit of a mystery when I first installed them (no instructions with the kit) why they applied when I released the handle. The adjuster caused them to get totally messed up until I started taking things apart to find the problem. I also had to change the leverage so I had enough pull on them to hold the car against the motor at idle. In fact I finally had to get a 3000 converter to finish this off. Works great now. I have pictures but it would be very difficult to see what I did unless you knew these inside and out. I really don't but I just followed the mechanics of them and adapted to them. Hotrodder lingo for "made them work the way I wanted them to, rather than the way they were designed to work."
Actually I think the disc unit that mounts on the front of the 9 inch rear end would be better if you have room. I know that the integral drum brake is supposed to work great but I just didn't want that style. Hard headed I guess.
Old 03-09-2010, 02:50 AM
powerrodsmike's Avatar
Wiki Edits: 161
My understanding and experience with cars with or without metering valves showed me that a metering valve only holds pressure from the fronts until 50 or so psi is reached. This keeps the fronts from doing all the work at low speeds. If you drive a non metered disc/drum car on slippery or loose surfaces, you'll find the fronts apply first, and they will skid just a little on the loose stuff. In normal braking the timing is correct, where the drum brakes in the rear give slightly more stopping power at the beginning of a brake application, but are quickly outpowered by the disc fronts as the pressure rises.
If you ever looked at the graphs that show actual stopping power, drum brakes have the advantage over disc at the beginning of an application, but they build up heat so fast that they become ineffectual in a short time. That's why you find rear discs on most anything these days.
I have used a 10# rpv several times on the gm low drag FRONT calipers to band-aid a low pedal , which retract about .020-.030", and had no dragging issues...If that Caddy piston retracts .050", as Frisco states, then it's most likely the same seal design as the low drag front caliper, and a 10# rpv would work fine.
IIRC, most all those Cad calipers were intended to be used with a stepbore master cylinder, which would deliver the larger amount of fluid needed to activate the brakes. Many hotrodders use a smaller plain bore master cylinder, hence the need for an RPV as a band-aid for a low pedal.
I agree with all the above posters, the Cad caliper is a PITA, to adjust and maintain and I wouldn't build a new system using them..Explorer or S-10 or Corvette style internal parking brakes are the way to go. I have also used the pinion mounted ones, and they are not very good, IMO.
Later, mikey
BE different....ACT normal.
Old 03-09-2010, 06:21 AM
Rickracer's Avatar
Originally Posted by powerrodsmike
.Explorer or S-10 or Corvette style internal parking brakes are the way to go....
Don't forget the "LS" ('98 + up) Camaro brakes either. I thought about doing them on my S10, but it's so light in the rear compared to a Camaro, it would have thrown the "natural" braking balance off. They would be a GREAT option for a passenger car though.
Problem setting up guts of ten bolt rwruther Transmission - Rearend 18 08-30-2007 10:07 PM
Valves GearHead69 Engine 3 10-13-2003 04:51 PM
Mixed up valves. meschnebly Engine 4 10-07-2003 07:55 AM
Cleaning valves babyface Engine 9 06-26-2003 03:49 PM
429 Exhaust Valves BigBlockBabe Engine 9 03-28-2003 03:24 AM
