Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
#1
Alittle1
127 edits
#2
Powerrodsmike
113 edits
#3
Techinspector1
103 edits
#4
Oldguy829
80 edits
#5
Chevythunder
50 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-27-2002, 03:56 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post Residual Pressure Valve??
I have a front disc and rear drum brake setup. Pedal was low and mushy, master cylinder under floor, so I put in new master cylinder ( larger capacity) and I am installing a 2 LB residual valve in line between master cylinder and proportioning valve. In rear lines I am installing 10 LB residual valve between master cylinder and proportioning valve. Is this correct place or should it be AFTER the proportioning valve?? I called ECI and tech man said " Install as close to master cylinder as possible" I am wondering if installing before proportioning valve will that location cause a malfunction of that valve?? Any expirence either way?? DAVE SHANK
Old 12-27-2002, 06:12 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post re: Residual Pressure Valve??
the valve will work fine the residual valve must be placed as close to the master as possible, the old masters has a residual valve in them, now they use external type.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
