Residual Pressure Valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2007, 12:13 AM
BMM BMM is offline
Hello. 1981 Monte Carlo Power Brakes, all factory. The brakes feel soft, almost mushy, but do effectivley stop the car. There is a fair amount of travel before the brakes actually begin to stop the car, and then work well.
There have been no signs of a leak, and the brakes never don't work. I've been wondering about residual pressure valves, and heard they maintain sufficient pressure to the brakes so they remain slightly engaged (not touching, obviously). Would these be the cure to the soft brakes?
Thank you.
Old 11-05-2007, 05:24 AM
aka Duke of URL
The rear circuit (drum brakes) already have a 10# residual valve in either the MC or combination valve.
Excessive pedal travel is usually contributed to-
  • Improperly adjusted rear drum brakes
  • Improperly adjusted MC pushrod
  • Swelling of brakes hose(s) on application
  • Internal leak in MC
  • Air in system
Old 11-05-2007, 09:13 PM
BMM BMM is offline
Alright, thank you.
Old 11-07-2007, 07:17 PM
The Maintenance Geek
  • Air in system
You forgot warped rotors, which will push the pads away from
the rotors giving you a long pedal...
K
Old 11-07-2007, 10:25 PM
aka Duke of URL
K
I did...
Will Rear Disc's Stop Better Than Rear Drums?? acr Suspension - Brakes - Steering 90 10-25-2012 07:01 PM
Valve seat pressure KNanthrup Engine 6 08-09-2005 03:07 PM
Roller Valve Spring open pressure? NXS Engine 9 03-13-2005 06:32 PM
Residual Pressure Valve useful? cboy Suspension - Brakes - Steering 3 03-12-2005 07:10 AM
Valve spring seat pressure too high? 84Z Engine 1 07-24-2004 12:00 PM
