Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Residual Pressure Valve??
Old 12-27-2002, 04:56 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post Residual Pressure Valve??
I have a front disc and rear drum brake setup. Pedal was low and mushy, master cylinder under floor, so I put in new master cylinder ( larger capacity) and I am installing a 2 LB residual valve in line between master cylinder and proportioning valve. In rear lines I am installing 10 LB residual valve between master cylinder and proportioning valve. Is this correct place or should it be AFTER the proportioning valve?? I called ECI and tech man said " Install as close to master cylinder as possible" I am wondering if installing before proportioning valve will that location cause a malfunction of that valve?? Any expirence either way?? DAVE SHANK
