Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Residual Pressure Valve BEFORE or AFTER Prop. Valve?
Old 10-16-2010, 09:28 AM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by 001mustang
One advantage of installing a 10# residual valve for drums is the slight pressure will help expand the wheel cylinder pistons; minimizing leaks. Another advantage of the 10# res press valve is to minimize pedal travel.
A 2# res press valve for the discs is most likely unnecessary unless mc is lower elevation than calipers. Caliper pistons tend to stay in position w/o encouragement from res check valve.
Okay you have talked me in to ordering a 10# for the rear and not worrying about the front discs . I have tried since I last read this thread to see if there was any difference in brake travel, and the pedal does seem to come up just a little bit higher if I hit it twice. Barely noticeable , but it is noticeable . I am all about safety and optimum braking so I'm going to place an order NOW .
