Residual Pressure Valve BEFORE or AFTER Prop. Valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2010, 09:20 PM
Do I plumb the 10# residual valve in before or after the wilwood adjustable prop valve I'm using?
I'm running a disc/drum system and know there needs to be a 10# valve in the drum circuit, but if someone could tell me where it needs to be and why, I'd really appreciate it.
Thanks,
Matt
Old 10-14-2010, 02:33 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Mat!
Welcome to Hotrodders.com. Glad to have you with us.
Click the link.
Good luck,
Rich
http://ecihotrodbrakes.com/brake_facts.html
Old 10-14-2010, 07:07 PM
ogre's Avatar
the 'Duracell Project'
residual valves are need when the mc is near or bellow the brake cyl or calipers.
they are needed to keep your pads closer to disc/drums
while it may not matter, i have always seen them and installed mine after all other valves
Old 10-14-2010, 08:52 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I'm not sure it matters either, but I have never seen them installed other than the following order - mc, residual pressure valves, other valves (such as a proportioning valve), then caliper / wheel cylinder. This is how I have them on my T. Just the opposite of how Ogre has seen them if I read his post correctly. Just goes to show ya' I guess when you're asking for advice on a public forum LOL!!
Old 10-14-2010, 09:12 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Well now I guess this means I need to go shopping for some residual pressure valves for my T-bucket . I don't think it has them and the master cyl is under the floor .
Old 10-15-2010, 08:31 PM
65ELCMO's Avatar
residual valves go after the combo valve. 2 # for the front disc and 10# for rear drum.
Old 10-15-2010, 11:23 PM
001mustang's Avatar
Some master cylinders have residual valves built in.
From the factory the residual valve has historically been installed in the master cylinder. The proportioning and metering valves are downstream of the residual pressure valve; cleaner install. Some after market conversion kits have residual valve downstream of the proportioning valve. I doesn't makes much difference where the residual valve is installed. Make sure your mc has no residual valve if you elect to install one.
One advantage of installing a 10# residual valve for drums is the slight pressure will help expand the wheel cylinder pistons; minimizing leaks. Another advantage of the 10# res press valve is to minimize pedal travel.
A 2# res press valve for the discs is most likely unnecessary unless mc is lower elevation than calipers. Caliper pistons tend to stay in position w/o encouragement from res check valve.
Old 10-16-2010, 12:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Most times the add-on residual pressure valves are located after other valves unless the valve is self contained in the MC.
Old 10-16-2010, 06:43 AM
001mustang's Avatar
If your car is equipped with a differential pressure brake warning switched distribution block; the proportioning valve must be installed down stream of your distribution block.
Old 10-16-2010, 08:06 AM
Mine are installed directly out of the m/c then combo valve. brakes work perfect,have for 9 years &32000 miles
Old 10-16-2010, 09:28 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Okay you have talked me in to ordering a 10# for the rear and not worrying about the front discs . I have tried since I last read this thread to see if there was any difference in brake travel, and the pedal does seem to come up just a little bit higher if I hit it twice. Barely noticeable , but it is noticeable . I am all about safety and optimum braking so I'm going to place an order NOW .
Old 10-16-2010, 11:15 AM
Thanks for all the info guys. Here's what I'm going to do: Use a 1968 Mustang disc/drum 1" bore master cylinder and add a 10# rpv and a Wilwood proportioning valve to the rear circuit. That outta cover my brake system. That will let me avoid the combination valve.
Old 10-16-2010, 12:45 PM
001mustang's Avatar
I would use a 68 drum/drum mc w/ internal rpv's; remove rpv from front disc mc port.
If new drum/drum mc does not have rpv you can rob one from your old mc.
a1 cardone no longer includes rpv in the cheap mc.
The drum/drum mc will fit (68 mustang). the disc/drum mc will not fit (68 mustang) w/o adapter.
Old 10-16-2010, 03:51 PM
001mustang's Avatar
If you are not an expert tube bender I would consider putting proportioning valve upstream of rear flex hose. You can hide proportioning valve somewhere behind rear seat. If you run too much tube up and down and have trouble bleeding high spot, you can add a high point tee for bleeding and for PSI gauge port.
Factory cars do have up and down runs; good to minimize these air catchers and to use small diameter tubes.
I have seen too many ugly brake line bends in the engine compartments.
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 09:29 AM
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
4l60E pressure regulator boost valve impalaman63 Transmission - Rearend 1 01-06-2009 07:11 AM
Residual Pressure Valve? BMM Suspension - Brakes - Steering 4 11-07-2007 10:25 PM
