RESIDUAL VALVES, for MC below WC. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 09:12 PM
machinist & fabricator
hay guys, im doin brake lines on a 30 olds im building.
it has all new mid 70's GM brakes, stock GM master cylinder,front disc and a GM 10 bolt with drum.
i deleted the old style proportion valve and went with an aftermarket knob style.
the master cylinder is mounted under the seat.
i have a 2 psi and a 10 psi residual valve so fluid wont leak back into the master.
my question is, does this 2&10 psi residual valve have to be mounted level?
or can it be mounted anywhere?
thanks guys.
B
Old 08-15-2006, 11:09 PM
BOBCRMAN@aol.com's Avatar
They don't have to be level, but, mount them close to the master as possible.
Old 08-16-2006, 05:54 AM
Wiki Edits: 49
Bob is right. Orientation doesn't matter but they should be relatively close to the master cylinder.
Old 08-16-2006, 11:16 PM
thanks guys, there within 10" of the MC... im guessin that is fine, right?
thanks again
B
Old 08-17-2006, 12:34 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
h0trod389 - hows the olds coming? Haven't seen any new pics on your web site. I guess you are doing the brakes now.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-17-2006, 07:00 PM
As Bob C said: "As close as possible". If 10 inches is as close as possible, then so be it. But if 10 inches is the easiest way, then I say work harder and do it right. This is a voice of experience!!
Trees
Old 08-18-2006, 03:23 AM
man, due to finances, i stopped for a bit.for about 4 months
well times are changin, i just got me a TIG so chassis work will be done soon...
i have done some minor changes.... due to practicality
and the website hasnt been updated... no FTP on this puter anymore.... just gotta get the program from a buddy...
itll be done soon!
Old 08-18-2006, 08:00 AM
35chev/302gmc's Avatar
I dont understand why the res valves have to be mounted as close to the master as posible. The hydrulic presure in the lines will be the same at 10 inches or 10 feet. Can any one explane why they have to be close to th M/C?
Thanks
1935 chevy,masters
Old 08-19-2006, 06:14 AM
That is a difficult question for me because I don't have a good answer. When I was in school, I had many questions like: 2 + 2 = 4. Why? " Because that is the way it is". I have read and been told many times by those that are more experienced than I, residual valves need to be installed as close to the master cylinder as possible. The installation instructions that come with all that I have purchased new tell me to install them as close to the master cylinder as possible. I have installed them at the easiest location only to go back and do the job right later and had improved results. These reasons are why I say they should be installed as close to the MC as possible. Yep, 2 + 2 = 4 and that is the way it is.
Trees
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 11:10 AM
Help installing residual valves upthcreek Suspension - Brakes - Steering 4 02-01-2006 05:03 PM
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 01:19 AM
What kind of machining needs to be done to run oversize valves? Dubz Engine 8 03-12-2005 08:55 PM
residual pressure valve Blob Suspension - Brakes - Steering 1 12-31-2004 04:45 PM
