Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - resistance of plug wires?
Old 10-08-2006, 08:11 PM
paulo 1 paulo 1 is offline
OK.Yes the modern Vortech does use much better seals ,fixed to the guides.
But lets see,it is definitely a problem isolated to that one cylinder only.You could even try swapping wires but I do not think it is the guilty part.Swapping plugs... If it is a multi point injection fuel system,you could have a bad injector.If it is TBI equipped or carbureted,it would more likely be a mechanical problem.How about checking the manifold port of that cylinder sucking for instance,ATF up the tranny tubing?
