Resizing OEM Aluminum driveshafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 07:30 PM
spinn's Avatar
Aluminum driveshafts have been on the lists for sale. A nice smooth rotation at higher rpms 2600-3000 cruise and the look make them desireable peices. Droping some rotating weight is a little help. Supposed parasitic electro mechanical reduction from a 55" spinning ferrous metal rod is eliminated recovering a loss in power. They are often under 75, then add a cut n balance another 100. These are OEM nice shafts from the 3R ujoint F bodys, 2500, marquis, and envoys. The same prop shafts are 450 from performance shops. Do you believe the 3.5" AL prop shaft is worth 150 total ?
Automatic avatar resizing tool? Graham M Hotrodders Site Suggestions and Help 1 08-08-2011 12:15 AM
new technique for image resizing Jon Hot Rod Art 2 10-18-2007 10:27 AM
Carbon Fiber Driveshafts - are they worth it? Mad Maggot Transmission - Rearend 6 10-30-2005 04:46 PM
Driveshafts..... broncoII88 Transmission - Rearend 1 04-27-2005 08:50 PM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 06:46 AM
