reskinning back of cab - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 09:35 PM
I started with some rust pin holes on the bottom of a 1950 chevy truck cab. After I welded them up the bottom edge of the panel shrank (as expected). Since I could not reach both sides of the panel to hammer it out I thought I could make some hot shrinks in the middle of the panel to even things out since welding the bottom gave it a bad case of the oil cans. didnt work so well. So I decided it would be less work to cut the panel out and make a new one then weld it back together. making the panel large enough that I could reach it through the door openings and rear window to work out the heat affected zone. I have made multipule attemps to upload photos to this thread but cant. However I was able to load them to my album.
http://www.hotrodders.com/gallery/sh.../89961/cat/500
Old 10-12-2010, 05:52 AM
deadbodyman's Avatar
Wiki Edits: 11
Looks good,I got a 54 to get started on someday..
Rant about aftermarket sheetmetal cyclopsblown34 Body - Exterior 27 01-28-2010 11:14 AM
corvette front clip rhinz1966 Body - Exterior 12 01-11-2010 05:57 PM
any help ya'l luvchevs Body - Exterior 6 01-06-2010 10:35 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
