Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Respirator for Silica Sand Blasting and Painting
Old 09-24-2011, 10:40 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
check out Mine safety Equipment as they have a good selection of respirators for various uses..On the media some of the medias cut better then others and use less media. I also do as much as possible with sanders and grinders and save the blast for the hard to get areas..
Sam
http://www.msanorthamerica.com/catal...log500013.html
Try those guys as their products are usually available from several local outlets so you can get replacement consumables easily. cartridges are a consumable item..I use a half mask and a hood my self when blasting..
